Techgod Clutched March 3, 2020 Share March 3, 2020 Cars with electronic braking system, i.e Toyota Safety Sense. ↡ Advertisement Link to post Share on other sites More sharing options...
Discoburg Supersonic March 4, 2020 Share March 4, 2020 On 3/2/2020 at 10:13 PM, Techgod said: Hearsay that nowadays for newer cars with all the electronics braking, it is not as simple as bleeding via vaccum/pedal depression. It requires some machine calibration. True? Wah! Like that I better not do mine first. 😥 Link to post Share on other sites More sharing options...
Volvobrick Supersonic March 4, 2020 Share March 4, 2020 (edited) I am scared of electronic brakes - if someone hacks and remotely disconnects the circuit how? Edited March 4, 2020 by Volvobrick Link to post Share on other sites More sharing options...
inlinesix Hypersonic March 4, 2020 Share March 4, 2020 2 minutes ago, Volvobrick said: I am scared of electronic brakes - if someone hacks and remotely disconnect the circuit how? Convention brake easier. Cut brake line. 1 3 Link to post Share on other sites More sharing options...
Discoburg Supersonic March 4, 2020 Share March 4, 2020 On 3/2/2020 at 10:13 PM, Techgod said: Hearsay that nowadays for newer cars with all the electronics braking, it is not as simple as bleeding via vaccum/pedal depression. It requires some machine calibration. True? Yeah just messaged a workshop mechanic and he said need to use some machine to bleed. Link to post Share on other sites More sharing options...
Techgod Clutched March 7, 2020 Share March 7, 2020 The risk is there, not sure if any workshop out there changing to SSBH have the appropriate tools/machine for the bleeding and with the correct set of OEM data. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Brake Pads
Brake Pads
Brake squeak every morning
Handbrake Lever up, does the brake light comes on?
