Frustrated Neutral Newbie January 12, 2003 Share January 12, 2003 Hi folks, Discovered this forum and hopefully someone can help. My car has been experiencing a loose steering in the last month. Making a turn doesn't see the steering returning to it's original position. Notice too i can turn the wheel like 30 degrees on a while travelling straight without any travel deviation. I've had it checked by several mechanics and there appears nothing wrong with the following: 1) Wheel Alignment 2) Wheel Balance 3) Steering Rack 4) Tie rods, shafts and steering wheel couplers. 5) Tyres pressure 6) Suspension joints. What else could be wrong? Pt. 6 wasn't really checked in detail as I witness, only the top joints were fiddled with sort of. How should the front suspension ball joints be checked? ↡ Advertisement Link to post Share on other sites More sharing options...
Wymun Neutral Newbie January 12, 2003 Share January 12, 2003 Have you tried Uncle Boon at Avioncar in AutoPoint?? He's good at diagnosing and fixing such problems... He just spoke to me about my steering rack, which has slightly more than usual free-play. But your case seems worse (as the steering doesn't seem to return to normal position). Do you need to jerk back your steering in that case, during U-turns?? I suggest you get it fixed fast, as it could be your entire steering box that needs fixing?? I think it may be considered rather dangerous... No harm to give him a call: AvionCar (Uncle Boon), AMK AutoPoint #05-35, Blk 10, Ang Mo Kio Industrial Park 2A, Tel: 64841911 Link to post Share on other sites More sharing options...
Saaber Neutral Newbie January 12, 2003 Share January 12, 2003 What car are yoou driving? Link to post Share on other sites More sharing options...
Sky8807 1st Gear January 12, 2003 Share January 12, 2003 Probably wear and tear. Steering at neutral, should be able to move about 1" to 1 1/2" either side with no disturbance to straight position. Sensitivity at zero position is like that, as u turn further the steering response become more sensitive. Check your steering wheel attachment gearing splines, maybe worn or not tighten securely. Link to post Share on other sites More sharing options...
Frustrated Neutral Newbie January 12, 2003 Author Share January 12, 2003 Wymun and all. Thanks for your posts. I'll call him and see what he says. Link to post Share on other sites More sharing options...
Vtim 3rd Gear January 12, 2003 Share January 12, 2003 Hi FRUSTRATED, welcome to MCF, better do it quick before something serious happens ↡ Advertisement Link to post Share on other sites More sharing options...
Steering leather wrapping
Steering column
Steering column
Paddle shifters - fixed to wheel or column?
the newest Mercedes model slk plaid
Reinventing the Wheel - Tesla Edition
Steering wheel off centered from seat.
