Lmws214 Turbocharged January 17, 2018 Share January 17, 2018 Just changed to this set of new eco tyres, Bridgestone EP 300 yesterday evening at SE Tyres Co with Uncle Ming. This new model is an upgrade from EP 200. My initial feel of this eco tyres on the road so far has been quiet (maybe becos it is new) but the grip on dry roads been doing well so far. Cornering at 60km/h has been a breeze. Stiffer sidewalls improve body roll which I like. What I like is that it has enhanced NanoPro-Tech with a new polymer that provides enhanced wet grip due to an increased contact area that grips wet road surfaces with higher frictional force at the micro-level. In addition, the new tread pattern contributes to anti-hydroplaning performance, better handling and reduced noise. I also learnt from Uncle Ming that the EP 300 deeper lug depth on the tyre shoulder is designed to strengthen durability and increase wear resistance. The tyre also features new tread design to better control tyre deformation and provide long-lasting tyre life through a uniform wear pattern. Will monitor the tyres further to see how it performs down the road. http://www.torque.com.sg/18675/bridgestone-introduces-ecopia-ep300-singapore/ https://www.bridgestone.com.sg/ecopia_ep300.html https://youtu.be/6CbgsequQoo ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Lmws214 Turbocharged January 17, 2018 Author Share January 17, 2018 . Link to post Share on other sites More sharing options...
Lmws214 Turbocharged January 17, 2018 Author Share January 17, 2018 Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged January 17, 2018 Share January 17, 2018 Uncle Ming and Uncle Hoe. My trusted tyre service providers since 1998! How much did your new tyres cost you? I see 195/55r15. Link to post Share on other sites More sharing options...
Lmws214 Turbocharged January 17, 2018 Author Share January 17, 2018 the 195/55 r15 is a photo i took of someone's car there. mine is 205/55 r 16. I trade in my stock rims and tyres for $350 for another used new rims that took it off from a civic. So I have paid for the Eco tyres for $570. It means rims one for one exchange. Uncle Ming is very patient and bothers to explain and clears my doubts. Cheers Uncle Ming and Uncle Hoe. My trusted tyre service providers since 1998!How much did your new tyres cost you? I see 195/55r15. Link to post Share on other sites More sharing options...
Skyum 1st Gear March 9, 2018 Share March 9, 2018 Autobac having offer for EP300. Just gotten my replacement 205/60R16 Made in Thailand Tyres for $388/4 (YOM 4217). My original 205/55R16 tyres did not give sufficient clearance for the car. So Bopian, change tyre to 1 size bigger and gain 10mm additional ground clearance. EP300Treadwear 300 Traction B Temperature A. Will see how long it last. The original BS T001 lasted 13months/25K only. Partly my fault..rotated tyres too late and by then my front tyres outer wornout.. Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 9, 2018 Share March 9, 2018 My Mich primacy 3ST has traction rated at A and I find it quite unacceptable let alone a B. I shall only consider traction AA the next change. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged March 10, 2018 Share March 10, 2018 Ecopia300 is more of comfort sedan tyres that’s focused on longevity and noise reduction looking at the fine lines. I also choose AA for traction only.. Michelin Latitude Sports3 AA instead of Primacy3 ST A Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged March 10, 2018 Share March 10, 2018 The worst Tyre I ever had is Toyo Open Country (made in Malaysia) that has a A traction... did a brake test on a hot day on a dry road along Marina Boulevard and E brake at 90kmh to zero and car skidded for a few metres. Did another 60kmh to zero and also skid. Changed the tyres out after that. So for some Tyre brand that you have not tried before, good to do a dry road brake test and wet road brake test on wide empty roads so that you will have a rough idea how the tyres will perform Link to post Share on other sites More sharing options...
Dynaway 1st Gear March 23, 2018 Share March 23, 2018 UTQG Traction rating is for stopping performance on wet road Link to post Share on other sites More sharing options...
DanielLee_201186 Neutral Newbie August 9, 2018 Share August 9, 2018 Hi All, Just changed to ecopia EP300 195/65/15 for 4 tyres.Damage S$280 in Johor Bahru. Link to post Share on other sites More sharing options...
Cypher 4th Gear August 10, 2018 Share August 10, 2018 Hi All, Just changed to ecopia EP300 195/65/15 for 4 tyres.Damage S$280 in Johor Bahru. You went to which shop? Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged August 10, 2018 Share August 10, 2018 Hi All, Just changed to ecopia EP300 195/65/15 for 4 tyres.Damage S$280 in Johor Bahru. Where? And how much if u chg in SG? Link to post Share on other sites More sharing options...
DanielLee_201186 Neutral Newbie August 10, 2018 Share August 10, 2018 Hawk Tyre Service Lot 8932 Jalan Bukit Satu Taman Sri Tebrau 80050 JB Tel : 607-3346276 195/65/R15 Price including balancing , fixing, nitrogen gas ,free warranty everything in .RM$900= S$300 Singapore i saw autobac selling 4 for S$639 Price including balancing , fixing, nitrogen gas ,free warranty carousell 195/60/R15 4 tyres S$340 Price listed is NETT. Inclusive professional fitment, Balancing, GST, 4 times Free Tyre Rotation Every 10,000km. Link to post Share on other sites More sharing options...
DanielLee_201186 Neutral Newbie October 21, 2018 Share October 21, 2018 Bro.. you spent rm900 for 4 tyres ? About $300, not $280 right ? $300 u mean? Yes.bro. should be S$300. Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged May 27, 2019 Share May 27, 2019 (edited) Just changed to this set of new eco tyres, Bridgestone EP 300 yesterday evening at SE Tyres Co with Uncle Ming. This new model is an upgrade from EP 200. My initial feel of this eco tyres on the road so far has been quiet (maybe becos it is new) but the grip on dry roads been doing well so far. Cornering at 60km/h has been a breeze. Stiffer sidewalls improve body roll which I like. Hi, need some feedback from you. Is the tyre noisy after the initital run in? after 5k? Still quiet now? I presume u would be covered as least 30k by now. Hope to get some feedback as I value quietness. Ep150 is noisy after 5k. Thanks in advance! Edited May 27, 2019 by Wildfaye29 Link to post Share on other sites More sharing options...
Lmws214 Turbocharged May 27, 2019 Author Share May 27, 2019 hi, not noisy afte rthe run in. still quiet. so far been quiet tyres for me,thanks! Hi, need some feedback from you. Is the tyre noisy after the initital run in? after 5k? Still quiet now? I presume u would be covered as least 30k by now. Hope to get some feedback as I value quietness. Ep150 is noisy after 5k. Thanks in advance! 1 Link to post Share on other sites More sharing options...
Skyum 1st Gear May 29, 2019 Share May 29, 2019 Autobac having offer for EP300. Just gotten my replacement 205/60R16 Made in Thailand Tyres for $388/4 (YOM 4217). My original 205/55R16 tyres did not give sufficient clearance for the car. So Bopian, change tyre to 1 size bigger and gain 10mm additional ground clearance. EP300Treadwear 300 Traction B Temperature A. Will see how long it last. The original BS T001 lasted 13months/25K only. Partly my fault..rotated tyres too late and by then my front tyres outer wornout.. Time to change the EP300 after 30,000K ( probably 15 months). Good handling with no incidents but not very lasting. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
