jaspal81 Clutched February 22, 2017 Share February 22, 2017 (edited) Hi all,Need some advise. I am scheduled for 50K servicing for my BMW 120I cabriolet and I just got it second hand. It is a 2011 model and is 5+ years old.I am considering going to juzz for cars for servicing. Need some advise if they are good and worth it?Also, I was told to change the following:1) Engine Oil2) Oil Engine Filter3) Gearbox Fluid4) Gearbox Oil Filter5) Rear differential fluid spark plug.Is the above all necessary to change?Appreciate your advise.Thank you in advance. Edited February 27, 2017 by Lightsabre ↡ Advertisement Link to post Share on other sites More sharing options...
Othello Supersonic February 22, 2017 Share February 22, 2017 (edited) 5yr old car. Sounds ok. Should have more in fact For eg. Brake fluid, coolant etc .... J4C, they are ok lah ... Edited February 22, 2017 by Othello Link to post Share on other sites More sharing options...
Loki Supersonic February 22, 2017 Share February 22, 2017 My advice is: 1. J4C is good with BMs. 2. Your (5) "Rear differential fluid spark plug" should be split into 5 and 6. 3. Should also check the brake pads and as Othello said, brake fluid. Also check power steering fluid. 4. Should be "advice" and not "advise". Link to post Share on other sites More sharing options...
Sunny Hypersonic February 22, 2017 Share February 22, 2017 i also went j4c in my last servicing asked me to change this change that scared liao nx round will go another workshop try Link to post Share on other sites More sharing options...
inlinesix Hypersonic February 22, 2017 Share February 22, 2017 i also went j4c in my last servicing asked me to change this change that scared liao nx round will go another workshop try Which 1 serves you? Anyway, it is good to get 2nd opinion. Sometime, it could be true to ensure that you stay away from tow truck. Last time, T2 told me to change water pump every 50k km. I did not do so. Water pump bearing jam and snap belt at 50+k km. It happens when i was doing parallel parking at 6am. I have to continue with parallel parking w/o power steering. Link to post Share on other sites More sharing options...
Sunny Hypersonic February 22, 2017 Share February 22, 2017 Which 1 serves you? Anyway, it is good to get 2nd opinion. Sometime, it could be true to ensure that you stay away from tow truck. Last time, T2 told me to change water pump every 50k km. I did not do so. Water pump bearing jam and snap belt at 50+k km. It happens when i was doing parallel parking at 6am. I have to continue with parallel parking w/o power steering. The manager Link to post Share on other sites More sharing options...
TameDriver Twincharged February 22, 2017 Share February 22, 2017 (edited) TS, I drive a Beemer too & I've been changing EO every 9-10k km from last servicing. Oil filter & aircon filter too. At 50K, better have aircon checked for gas. Since u got it preowned, have the brake pads checked. Tyres....change it if 3 yrs or more. Tyres needed to be changed every 40K or 3 yrs with normal road usage. Edited February 22, 2017 by TameDriver 3 Link to post Share on other sites More sharing options...
jaspal81 Clutched February 22, 2017 Author Share February 22, 2017 My advice is: 1. J4C is good with BMs. 2. Your (5) "Rear differential fluid spark plug" should be split into 5 and 6. 3. Should also check the brake pads and as Othello said, brake fluid. Also check power steering fluid. 4. Should be "advice" and not "advise". Thanks for the English lesson. TS, I drive a Beemer too & I've been changing EO every 9-10k km from last servicing. Oil filter & aircon filter too. At 50K, better have aircon checked for gas. Since u got it preowned, have the brake pads checked. Tyres....change it if 3 yrs or more. Tyres needed to be changed every 40K or 3 yrs with normal road usage. Thanks. I was told by juzz for cars that they can't do rear differential fluid because they do not have drain plug. Is that true and what's a drain plug? Link to post Share on other sites More sharing options...
Kb27 Supersonic February 22, 2017 Share February 22, 2017 Thanks. I was told by juzz for cars that they can't do rear differential fluid because they do not have drain plug. Is that true and what's a drain plug? It depends on your car design. Here's a video on changing rear differential fluid. Sometimes there's a drain plug or fill plug. That's where you tighten/loosen the plug to enable drain or fill through a hole in the differential. Link to post Share on other sites More sharing options...
jaspal81 Clutched February 22, 2017 Author Share February 22, 2017 It depends on your car design. Here's a video on changing rear differential fluid. Sometimes there's a drain plug or fill plug. That's where you tighten/loosen the plug to enable drain or fill through a hole in the differential. Thanks! I was told mine don't have drain plug... like that how to change? Link to post Share on other sites More sharing options...
Kb27 Supersonic February 22, 2017 Share February 22, 2017 Thanks! I was told mine don't have drain plug... like that how to change? If you watch the video, they just removed the bolts and let it drain out from the cover. Then clean up, put on a gasket and put back the bolts. There's a fill hole behind the differential, where they stick a 3/8" or 1/2" extension to remove the fill plug, so that you can push the gear oil into the differential. Then put back the plug and tightened to prevent any oil from coming out. Link to post Share on other sites More sharing options...
jaspal81 Clutched February 22, 2017 Author Share February 22, 2017 If you watch the video, they just removed the bolts and let it drain out from the cover. Then clean up, put on a gasket and put back the bolts. There's a fill hole behind the differential, where they stick a 3/8" or 1/2" extension to remove the fill plug, so that you can push the gear oil into the differential. Then put back the plug and tightened to prevent any oil from coming out. Does that mean juzz for cars is lying to me? Cause they told me can't be done due to the fact that there is no drain plug? Link to post Share on other sites More sharing options...
Kb27 Supersonic February 22, 2017 Share February 22, 2017 Does that mean juzz for cars is lying to me? Cause they told me can't be done due to the fact that there is no drain plug? Well, I wouldn't know. Maybe they don't do this kind of servicing ? Anytime you remove the bolts on the cover, the oil would all flow out. Some cars may have a drain plug to more "elegantly" drain the oil than loosening the cover and all the oil splash out. Link to post Share on other sites More sharing options...
jaspal81 Clutched February 22, 2017 Author Share February 22, 2017 Well, I wouldn't know. Maybe they don't do this kind of servicing ? Anytime you remove the bolts on the cover, the oil would all flow out. Some cars may have a drain plug to more "elegantly" drain the oil than loosening the cover and all the oil splash out. Ok thanks so much! Link to post Share on other sites More sharing options...
Kb27 Supersonic February 23, 2017 Share February 23, 2017 Found this video for BMW 1 rear differential. It has only 1 service hole and use a 14mm allen key. The author mentioned you can replaced the oil by sucking out from that hole and refilling it through the same hole. It doesn't look very difficult or need a very special tool. It's good to change out the oil with the correct spec type. 1 Link to post Share on other sites More sharing options...
Mkwng Neutral Newbie February 23, 2017 Share February 23, 2017 Free diagnostic service to assess your car's issue so you can get it repaired correctly! We offer best quality gearbox and clutch repair service. We are specialized in new automatic car gearbox repair & replacement and have gearbox repair specialist in Singapore. Whether you want reconditioned gearbox repair, car servicing or accident repairs, you can always turn to us! For Booking or Enquiries, Please Call or WhatsApp @ 93864011 Link to post Share on other sites More sharing options...
Neutrino Supercharged February 23, 2017 Share February 23, 2017 When you buy second hand car don't you also get given the service manual??? Should tell you what you need to service. Also can check out online if no manual. ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
Servicing car at Shell station
Volvo Servicing
Volvo Servicing
Servicing at Tan Chong
