QQDreamer 4th Gear August 6, 2016 Share August 6, 2016 Hi all, i am planning to get a honda civic 2nd hand. however there are this term call FD1 and FD2. May i know what is the difference between the 2 of them? Any bros can advice? ↡ Advertisement Link to post Share on other sites More sharing options...
Jtb 6th Gear August 6, 2016 Share August 6, 2016 http://www.ozhonda.com/forum/showthread.php?102198-difference-between-civic-fd1-and-fd2 1 Link to post Share on other sites More sharing options...
Tcx607 4th Gear August 6, 2016 Share August 6, 2016 FD2 is using K20Z engine. This is a high screaming engine giving sweet sound to fanboys. The mid and high range is very linear which hit red line easily. Most fanboy will modify this engine for performance. This engine operate at high temp and hence you need to TOP up EO every 3-4 weeks. Suspension is firm compare to FD1. Both have different spec and FD1 is meant for comfort. The rest are accessories and non performance. Link to post Share on other sites More sharing options...
Mawaflight Clutched August 6, 2016 Share August 6, 2016 Hi all, i am planning to get a honda civic 2nd hand. however there are this term call FD1 and FD2. May i know what is the difference between the 2 of them? Any bros can advice? FD1 Hydraulic power steering Single Cam FD2 EPS DOHC get the FD2, Superb engine performance even after 200k of mileage. 1 Link to post Share on other sites More sharing options...
Ichibawa 5th Gear August 6, 2016 Share August 6, 2016 FD1 = 1.8 FD2 = 2.0 FD3 = Hybrid FD4 = 1.6 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear August 6, 2016 Author Share August 6, 2016 FD1 Hydraulic power steering Single Cam FD2 EPS DOHC get the FD2, Superb engine performance even after 200k of mileage. FD2 is the 2000cc civic right? FD1 = 1.8 FD2 = 2.0 FD3 = Hybrid FD4 = 1.6 oh FD4 is 1.6? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear December 27, 2016 Author Share December 27, 2016 FDs using timing belt or timing chain? 1 Link to post Share on other sites More sharing options...
gausses Clutched January 19, 2018 Share January 19, 2018 (edited) I am using a FD2 fitted with K-Sport BBK (front and back). Although is a 12 years car, it is still very powerful and not to mention the aesthetic look. Thumb up for FD2. Edited January 19, 2018 by gausses 3 Link to post Share on other sites More sharing options...
Machunk28 4th Gear January 19, 2018 Share January 19, 2018 I am using a FD2 fitted with K-Sport BBK (front and back). Although is a 12 years car, it is still very powerful and not to mention the aesthetic look. Thumb up for FD2. How is the K Force BBK? Used for how long? Overall rating? 1 Link to post Share on other sites More sharing options...
gausses Clutched January 19, 2018 Share January 19, 2018 gausses, on 19 Jan 2018 - 11:15 AM, said: I am using a FD2 fitted with K-Sport BBK (front and back). Although is a 12 years car, it is still very powerful and not to mention the aesthetic look. Thumb up for FD2. How is the K Force BBK? Used for how long? Overall rating? Gausses: 3 months at the front and 2 weeks for the rear. The braking force is much better and almost instant stop at low speed. I never try other brand like AP, Brembo but K-Sport is quite good. The only thing is the Caliper is way too big and need to have 17" above to clear. I need to add in spacer front and back and cost me extra $ to lengthen the screw. Link to post Share on other sites More sharing options...
Firdooze09 Neutral Newbie September 16, 2018 Share September 16, 2018 Hi, just to check with you all, how much will it cost to replace an FD1 timing chain (and other parts associated with it) + labour? Hope you guys can help. Thanks! 1 Link to post Share on other sites More sharing options...
mistergoh 2nd Gear September 19, 2018 Share September 19, 2018 engine is different. FD2 use K20 engine 1 Link to post Share on other sites More sharing options...
Keithchue 5th Gear September 19, 2018 Share September 19, 2018 red top? 1 Link to post Share on other sites More sharing options...
YungRichPrince Neutral Newbie December 1, 2018 Share December 1, 2018 Hi I own Honda Fd2 Sports Sedan (Australia doesn't have the Type R) and I was wondering if coilovers off an Fd2 Type R would fit, also the motor is a K20a and there are some models I think there's a luxury model as well that has 1.8L but mine is not a Type R but Sport and has a K20, I also realise there isn't a lot of discussion about this, so in conclusion would for example a air intake or manifold fit on my non type R K20a Fd2 Sports Sedan fit? 1 Link to post Share on other sites More sharing options...
Heavenice 1st Gear February 21, 2019 Share February 21, 2019 Hi I own Honda Fd2 Sports Sedan (Australia doesn't have the Type R) and I was wondering if coilovers off an Fd2 Type R would fit, also the motor is a K20a and there are some models I think there's a luxury model as well that has 1.8L but mine is not a Type R but Sport and has a K20, I also realise there isn't a lot of discussion about this, so in conclusion would for example a air intake or manifold fit on my non type R K20a Fd2 Sports Sedan fit?FD2 sedans can interchange a lot of chassis and engine parts with FD2R but unfortunately suspension is not one of them. 1 Link to post Share on other sites More sharing options...
Heavenice 1st Gear May 7, 2019 Share May 7, 2019 Hi I own Honda Fd2 Sports Sedan (Australia doesn't have the Type R) and I was wondering if coilovers off an Fd2 Type R would fit, also the motor is a K20a and there are some models I think there's a luxury model as well that has 1.8L but mine is not a Type R but Sport and has a K20, I also realise there isn't a lot of discussion about this, so in conclusion would for example a air intake or manifold fit on my non type R K20a Fd2 Sports Sedan fit? Your engine should belong to the K20 series. Air intake and manifold are exchangeable between all FD with K20 series. Hi, just to check with you all, how much will it cost to replace an FD1 timing chain (and other parts associated with it) + labour? Hope you guys can help. Thanks! Easily a $250 upwards job FDs using timing belt or timing chain? all chains ↡ Advertisement Link to post Share on other sites More sharing options...
Takata airbag recall
