Ruggles Neutral Newbie September 23, 2009 Share September 23, 2009 Juz happen last nite as hv not service long time. Anybody got aircon servicing lobang & wats the cost? ↡ Advertisement Link to post Share on other sites More sharing options...
Konken Clutched September 23, 2009 Share September 23, 2009 If it's one off cleaning, should be around $40/ fancoil unit. Some can be slightly cheaper.... make a few calls to compare. Link to post Share on other sites More sharing options...
Osiris 1st Gear September 23, 2009 Share September 23, 2009 Most likely the piping is stuck with accumulated dirt. If you have a wet & dry vacuum, you can stick it up the pipe where the water drip out and suck em out. You should also DIY clean the unit regularly esp the filter Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 23, 2009 Share September 23, 2009 if don ve wet type vacuum, use water hose to flush it out. simply unplug e drain hose from e fan coil n flush from there, be prepare as it may get a bit wet Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear September 23, 2009 Share September 23, 2009 if don ve wet type vacuum, use water hose to flush it out. simply unplug e drain hose from e fan coil n flush from there, be prepare as it may get a bit wet I didn't use a hose. Instead, I pour hot water into the drain pipe from the fan coil and flush from there, it works well. But for better result, it is good to borrow a wet & dry vacuum. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear September 23, 2009 Share September 23, 2009 Juz happen last nite as hv not service long time. Anybody got aircon servicing lobang & wats the cost? You can actually DIY if you have the wet vacuum or ask around to see if any of your friend have 1. Take a look on how to DIY. http://www.youtube.com/watch?v=c7gONf6sIHY...feature=channel I have service my own. Time taken to clean A/C = about 1 1/2 hours (includes dismantling of cover from fan coil units x2, leaving the vacuum running for 1/2 hours). Cost: $0 (borrow vacuum from a friend). Aside: do clean the a/c filter regularly. I pasted 3M a/c filter and would change that every 2 monhts. Link to post Share on other sites More sharing options...
Albeniz Turbocharged September 23, 2009 Share September 23, 2009 I just serviced my air-con about 2 months ago. Managed to solve the dripping problem. Recently, the air-con became noisy when turned on. Does anyone know what could be the likely cause? It is able to blow out cold-air though. Link to post Share on other sites More sharing options...
Unfair 3rd Gear July 31, 2010 Share July 31, 2010 Oh dear, i am having the same problem with a leaking aircon. Does anyone have contacts for a serviceman to come repair it ? Link to post Share on other sites More sharing options...
Albeniz Turbocharged July 31, 2010 Share July 31, 2010 Oh dear, i am having the same problem with a leaking aircon. Does anyone have contacts for a serviceman to come repair it ? I engaged this gentleman (by recommendation of the folks in MCF) for servcing/repair: Daniel @ 97462194 Quite happy with the work. Link to post Share on other sites More sharing options...
Booboon 1st Gear July 31, 2010 Share July 31, 2010 daniel is good. He service my aircon. Now I DIY. Can really save alot. U can buy those filter at daiso, $2 per pack can last u 6 months. Link to post Share on other sites More sharing options...
Unfair 3rd Gear July 31, 2010 Share July 31, 2010 Okay, i try to call him and arrange. Many thanks bros !! Link to post Share on other sites More sharing options...
Doraemon84 Neutral Newbie September 17, 2011 Share September 17, 2011 Okay, i try to call him and arrange. Many thanks bros !! lucky i found this forum. Been having some headache in getting my aircon fix. Tried may aircon company but still my aircon leaking water problems come back less than 2 months. Link to post Share on other sites More sharing options...
Tom_kkh 1st Gear September 17, 2011 Share September 17, 2011 avoid I-cool servicing. they always advertise in the classified ads.. I hate rooms without aircon! Link to post Share on other sites More sharing options...
Nemo6089 1st Gear September 17, 2011 Share September 17, 2011 You should service your aircond yourself every month. Thrust me, it is not as easy as the Mitsubishi advertisement by using a vacuum cleaner to "clean clean here and clean clean there". You have to remove the front and the drain below the heat exchanger. Then use a 1" width paint brush that you have cut off about a 1/4" of the bristle to brush clean the blower dirt. After brushing the blower, plug a rubber hose onto the condensate drain leaving about 6 inches outside. You can tape some masking tape onto the end of this rubber hose so that when you plug it into the condensate drain it fits snugly. Next find a plastic bottle with a nozzle, fill it up with water and squeeze the water into the rubber hose till the water fill up the rubber hose. Blow into the rubber hose quickly to force out the algae inside the condensate drain. A few bottles of water will clear all the choke Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged September 17, 2011 Share September 17, 2011 lucky i found this forum. Been having some headache in getting my aircon fix. Tried may aircon company but still my aircon leaking water problems come back less than 2 months. Advertising????? Link to post Share on other sites More sharing options...
Donut Supercharged September 17, 2011 Share September 17, 2011 (edited) U should do 2 ways of servicing. One is engage air con ppl to regularly clean and check yr air con. 3 times a year. I just had my servicing this morning. They will take out covers. Vacumn the fins, clean the fins, wipe the blowers (note that fungus will grow on your blowers if u don't wipe them regularly), check leaks, check and clean compressor. I just learnt one new thing this morning. The compressor fins also need washing due to dust and dirt. They can spray water into the fins. But the problem is u need to tell all your neighbors below about it coz the dirty water will drip down. Another method is use compressed air to blow the fins. If your air con is not cold, it may be due to compressor fins dirty with dust and whatever. The chop carrot service guy may not want to tell u this, and he may tell u another bull story about other parts spoilt. The other one is DIY in between the regular service. If u r lazy type, just buy the spray can for air con cleaning, and just spray into the fins. No fuss at all. I do both ways. U can't really do without the proper air con company servicing because they will offer expert technical advice if necessary. And u can just do DIY between the regular servicing. I also learn that u need to use your air con once a while, if u dont have the habit of using any particular unit for long time (example your spare room or living room). The reason is because the value in the compressor will get jam if u don't use the air con unit for too long. Once jam, it costs $100+ to change it. Turn on once a month for 5-10 mins will do the trick. I engaged Aire Control for the servicings. So far no problem for 3 years with them. At least they never chop carrot me. Edited September 17, 2011 by Donut Link to post Share on other sites More sharing options...
Goyce Neutral Newbie January 21, 2012 Share January 21, 2012 Juz happen last nite as hv not service long time. Anybody got aircon servicing lobang & wats the cost? Not sure about the market price really. Mine done by Aircon Singapore. Cost about $30 to $35 a unit. When was the last time your service your aircon? Normally people do it once every 3 to 4 months. Link to post Share on other sites More sharing options...
Happily1986 5th Gear March 29, 2012 Share March 29, 2012 Would like to revive old thread to ask bros here. Recently the aircon split unit has been noisy and the air flow is not very uniform. The noise is best characterised with the noise that you get from interference when you switch on a fan in the face of an oncoming breeze. [compressor]---------[split 1]---------[split 2]--------[split 3] split unit 2 is in long periods of disuse because my sister is overseas. the problem has been observed for split units 1 and 2. This is a relatively new Daikin Inverter System 3. Last servicing was about half year ago. Any clue? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Car air-con
Car air-con
Simple home DIY repairs
Home Aircon
Home Aircon
Dehumidifier recommendations
